Hi,
I was replacing my rear brake discs and pads and the handbrake spring bolts fell off.
The alen bit of the screw with the spring seems to be made to go through the front and it basically hooks on the dust shield of the brake disc.
The problem is that probably due to rust the hole that this screw hooks on is very large so those screws wouldnt stick in from the front.
I am not an engineer so maybe what i did is stupid, but i put them backwards so that the screw and spring are against the dust shield and the hook grabs the handbrake pads that are solid.
I cant see any issues with it being backwards, to me it seems like it shouldnt pull the shield any more causing interference with the disc and they wouldnt really come off very easily even though they are exposed.
The whole point i started this was because of grinding noises in the rear. So far looks like discs and pads were worn but handbrake is looking bad too, could need adjusting. I may just get rid of it if i buy a hydro brake.
My question is, is the backwards bolt stupid?
Thanks!
Thanks!
