FIXD OBD Scanner
IanA
Oxon
I've used my Creator scanner successfully on my two rebodies but Instagram has just popped up an extended advert for the FIXD scanner. It looks as if it can do a lot that the Creator does for me but by adding a paid subscription it will make toast and coffee (exaggeration) along with providing car history, mechanical history and even a prediction of repair costs if problems are found.
The main selling point is that it can be used to scan a car that you are about to buy and let you know instantly of any/all potential borkage.
Offered ar £29.99 (less than the Amazon price)- has anyone on here experience of using same?
Its rubbish, stick with the Creator 310+ or upgrade to the 410 model.
Derendran
The FIXD OBD scanner definitely makes basic code reading and maintenance reminders more accessible for casual Jeep owners, but it’s good to remember its limitations compared to more advanced tools with live data and custom PIDs. If you’re trying to decide whether it’s worth the investment, think about how deep you want to go with diagnostics long‑term. And when you’re documenting your testing or sharing results with the community, https://comfax.com/resources/fax-cover-sheets/ has a really useful set of fax cover sheet template that make organizing and presenting your logs neat and professional.
thanks for the information!
