ABS & Brake warning lights on dashboard
NeRo
Linlithgow
Recently had all the brake pipes replaced - after a couple of weeks, I now have the ABS & Brake warning lights on the dashboard
I put it back to the garage and they put it on the diagnostic machine - the following codes were shown
  1. 5E40 - Steering angle implausible
  2. 5E32 - Transverse acceleration signal
  3. 5DF4 - System voltage <9 volts
  4. 5E30 - Transverse acceleration sensor
They seem to think it is the lateral acceleration sensor at fault, but this costs >£700
Anyone had or know of this problem and can offer any advice?
Thanks
hard top
Dutch Zeds
Netherlands
Nice to read from you again @NeRo, you going to get your finger out one day and do a bit of modding on here?
Wheel sensor fault throws those dashboard lights.
Antm72
South Yorkshire
Is the battery good ? It's advising poor voltage which could trigger the others ?
Brian H
Killin
E36/7 3.0i - E85 Z4///M
I would clear the faults Nero and see what comes back, I have seen a few transverse acceleration sensors fails, you can pick them up second hand sometimes. Have you by any chance had any water in the passanger footwell?
markvrs
Z3 2.8 Roadster & Z4 2.0 M-Sport E89
Just done all my brake pipes as well. Also had several fault codes that had me confused, unable to clear them through OBD. Changed a speed sensor and ABS module chasing the problem. Took it for a drive twice (2 miles each) - still with fault codes.
Since all I had done was replace brake lines and pipes I was assuming it was a coding issue somewhere as I had turned power on and off with sensors disconnected or some thing.
I admitted defeat , first time I had a problem beat me and booked it into a BMW specialist. Drove off there with my warning lights mocking my failure in my face and then half way there (6 miles) , they all went out.... Specialist said nothing wrong , no codes.
So fully charge your battery and take it for a good drive. Never know your luck.
Anybody want a ABS Pump and ECU Module ATE mk20 for Z3 2.8 :)
NeRo
Linlithgow
Thanks for the feedback - haven't been able to do much as the bonnet is stuck and I can't open it myself ~ new parts ordered
  1. The battery is a few years old and I did have a problem a few weeks ago when it went flat and I had to recharge it
    It has been OK since, but maybe worth a quick charge
  2. Car is dry inside
  3. The codes above, were after a reset - codes could not be cleared
  4. One thing I did notice was that the brake fluid reservoir was overfilled - so much so it was level with the lip ~ I've removed some fluid to get it to the max mark
